CRX starting problems
Old Jun 24, 2003 | 07:18 PM
cheeposvw's Avatar
cheeposvw
Default CRX starting problems
I just completed an engine swap in my son's 88 CRX HF. The car started, but when shut off refused to start again. I checked the computer, and got a fault code for ignitor and fuel injection. I replaced the distributor, throttle body, wiring harness, fuel relay and filter. Had good pressure and the car started fine. After driving for about 30 minutes, I shut it down, and it wouldn't restart. I cleared the fault codes and retried. Got the fuel injector code again. Checked everything, the car started and ran fine for a day. Tonight.....you got it! no start. This time, I didn't even get a start up flash from the computer, so I replaced it. No start....fires on starting fluid, but no go on fuel injection. I'm running out of hope and my parts car is almost bare. Any ideas?
Old Jun 24, 2003 | 07:30 PM
4thgen91EFhatch's Avatar
4thgen91EFhatch
Main Relay?
Old Jun 24, 2003 | 07:58 PM
excitid's Avatar
excitid
http://www.fourthgenhatch.com/mainrelay.html this will tell you how to change it.. Courtesy of fourthgenhatch
Old Jun 24, 2003 | 08:11 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Yeah it sounds like it could be a Main Relay. I guess its just a coincidence it happened right after your swap was done.
