Stage 3 clutch
Old Jun 22, 2003 | 06:35 PM
Pete's Avatar
Pete
Civilian
Default Stage 3 clutch
So, apparently I have a stage 3 racing clutch in my 90' rex :naughty: . What exactly does that do for me other than make it harder to shift?
Ya'll are probably like "What in the hell? This kids a trip." Followed by, "This kid says "ya'll" and he's from NY?"
Old Jun 22, 2003 | 07:06 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Just means the clutch should be capable of holding more power than the stock clutch, by about 30-50%.
-Harry
AIM: NDcissive
Old Jun 22, 2003 | 08:23 PM
crxb16er's Avatar
crxb16er
yah means the disc will stay engaged under a greater torque load, what it means to u is that hopefully itll last longer and itll stick if u drop the clutch at a launch. shouldnt make it harder to shift at all though
Old Jun 22, 2003 | 08:25 PM
crxb16er's Avatar
crxb16er
thats probably a bushing issue, check out the connection at the bottom of ur shifter connecting it to the shift linkage and see if the connection is worn out
Old Jun 23, 2003 | 06:41 AM
Pete's Avatar
Pete
Civilian
what type of clutch does the car come with stock, a stage 1?
Old Jun 23, 2003 | 11:40 AM
jung4g's Avatar
jung4g
Asianalize your car
Comes with OEM... you could call it a Stage 0 if you want. A stage 1 clutch is an upgrade for more power handling and light race use. Stage 3 is overkill for street, and you probably won't have enough power to need it... that's cool though
Jung
Old Jun 23, 2003 | 11:51 AM
Pete's Avatar
Pete
Civilian
Yeah, I feel like there's just too much power there in the first 2 gears. Way more than there needs to be. But what's cool is, I feel a power change in every gear.
Old Jun 23, 2003 | 12:37 PM
Pete's Avatar
Pete
Civilian
Well, a noticeable one, because usually when u switch from like 4th to 5th it's not all that much
Old Jun 23, 2003 | 12:48 PM
crxb16er's Avatar
crxb16er
a stage 3 clutch will allow u to drop the clutch and have ur car peel out right away because the tranny engages the flywheel alot harder, with a oem clutch if u drop the clutch u may peel out u may just notice a slower gain of speed as the clutch takes its time completely locking up.
Old Jun 23, 2003 | 02:12 PM
excitid's Avatar
excitid
IS it harder to shift or harder to push in the pedal. My pedal was hard as hell to push turned out the clutch cable was going bad changed it and it was smooth and light again. Check you tranny fluid if you having any grinding problems. After doing the clutch cable and fluid on the wagon its been shifting like a new car.
