d15 check engine help
Old May 22, 2003 | 01:03 PM
muff diver's Avatar
muff diver
MUFF DIVER
Default d15 check engine help
hi i have a 1991 civic wagon with the d15 motor, and starting today the check engine light has come on
i looked at the ecu code under the front foot panel on passenger side
and the lights are blinking
16 quick blinks
pause
17 quick blinks
pase
16 quick blinks...and so on
can someone help me with what this might be?
Old May 22, 2003 | 07:13 PM
muff diver's Avatar
muff diver
MUFF DIVER
nobody knows?
Old May 23, 2003 | 05:36 AM
excitid's Avatar
excitid
http://www.crxsi.com/resources/manual/ecu_codes.htm
Code 0 _____ Faulty ECU
Code 1 _____ Oxygen content
Code 2 _____ Does not appear to exist
Code 3 _____ MAP sensor
Code 4 _____ Crank angle sensor
Code 5 _____ MAP sensor again
Code 6 _____ Coolant temperature
Code 7 _____ Throttle angle
Code 8 _____ Top dead center sensor
Code 9 _____ No. 1 cylinder position (only on 1.6L)
Code 10 ____ Intake air temperature
Code 11 ____ Does not appear to exist
Code 12 ____ Exhaust gas recirculation system
Code 13 ____ Atmosphric Pressure
Code 14 ____ Electronic air control (EACV)
Code 15 ____ Ignition output signal
Code 16 ____ Fuel injector
Code 17 ____ Vehicle speed sensor
Code 18 ____ Does not appear to exist
Code 19 ____ Lock up control solenoid (auto trans only)
Code 20 ____ Electric load
Old May 23, 2003 | 08:27 AM
muff diver's Avatar
muff diver
MUFF DIVER
that is weird car runs perfect and speedometer works fine..
:sigh:
Old May 23, 2003 | 02:37 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Pop the hood, look at the fuse box, there will be a fuse that says hazard, pull that fuse for my 10 seconds and then put it back in and start the car, see if it still throws codes.
Old May 23, 2003 | 02:38 PM
muff diver's Avatar
muff diver
MUFF DIVER
thanks i will attempt that
Old May 25, 2003 | 09:17 AM
crxb16er's Avatar
crxb16er
i completely agree, pull the hazard fuse or just disconnect ur battery for about 30seconds, then put it all back together, run ur car, see if it lights up, if it does check ur ecu, see what code it is and go from there or post the results and we'll give u some insight. fuel injector may have gotten clogged and then started spraying again? could be a lot of things
Old May 25, 2003 | 11:36 AM
muff diver's Avatar
muff diver
MUFF DIVER
i just disconnected the battery and the ecu fuse....will go driving today
Old May 26, 2003 | 06:10 AM
crxb16er's Avatar
crxb16er
with ur lack of another post hopefully u fixed ur own problem.
Old May 26, 2003 | 08:17 PM
FourthGenHatch
Don't disconnect the battery to clear out the ECU codes, because then you have to reset your clock and radio settings, if you just pull the hazard fuse that stuff won't be erased with it.
