starting question...not sure if i asked before
well knock on wood it hasn't happen since this episode.
about a week and a half ago, rather warm day, i went to the sotre blah balh to make a long sotry short...
i started my car and it just started like bogging slowly until it was shaking and almost stalled....i turned the car off and tryed again...same thing, i popped the hood and pushed all my wires on my distro cap tight....and it worked, no problems...
but then 10 mins later after another stop it did the same thing?
hasn't done it since....wtf could it have been?
doIhaveBDIs,
Since you fixed the problem by making a better connection between the wires and the cap, I'd think that whatever wires you have on there might not fit the cap as perfectly as they should. Try putting a set of Honda wires on there to see if that fixes the problem.
Timing belt skipped a tooth? I'd think the problem would not be intermittent if that was the case.
Bogatyr
Bogatyr
