short shifter ???
Old Apr 26, 2003 | 09:39 AM
Project_Rage's Avatar
Project_Rage
Default short shifter ???
If im going to put a B18 in my CRX later should i bother getting a short shifter for my CRX now ??
Will i have to get a Integra one ???
If I got a Integra one now will it fit my CRX ?
How are SOLO shifter ??
what should i look for in one ?? I have herd of ppl braking short shifter y is that??
what should it be made out of ??
Old Apr 26, 2003 | 02:50 PM
crxb16er's Avatar
crxb16er
yah a short shifter doesnt really do nething special just makes it so there is less space for u to move the shifter b4 u hit the next gear, shift linkage is what changes when u get a new engine so go for it, they are all about the same, there are no special brands, it is very easy to install urself, u can get one for the car u have, doesnt matter what engine u get later.
Old May 5, 2003 | 01:03 PM
Project_Rage
so even if i get a 2001 B18 and convert the car to hidro i will still be able to use the same short shifter?
and it doesn't matter what its made out of right?
Old May 5, 2003 | 01:18 PM
crxb16er's Avatar
crxb16er
yah just the shifter makes no difference, if u change to a hydro tranny later on that is just how u release the clutch plate not how u put it into gear. you can use whatever short shifter is made for ur car, and when u eventually swap engines u just use different sized shift linkage to actuate the gears on the different tranny. shift linkage is what is attached on the bottom of ur car and goes to ur transmission, jack ur car up and take a look its very simple when u look at it all to understand, kinda weird trying to explain it though, i dont know what they are made of but get one with new bushings on the for the lower connection, i believe all of them come with new bushings just make sure u install them. just go out buy a short shifter and itll have instructions on how to do it.
Old May 5, 2003 | 05:06 PM
onebadassdx's Avatar
onebadassdx
i'm runnin a solo short shifter in my b16a...its awesome, nice and short and it doenst give you the feel of being in the wrong gear
