integra dash in a crx....
Originally posted by crxb16er
i'm sure it can be done but, i don't think it can be done fairly easily, i think itd be pretty taxing and hard to do right
im sure it can be done.. just how much time do you have and patience???
schwanginpt:
The interior in my 87 isn't (obviously) lookin to well, what paint would you recommend using when painting? After I get all my body kit parts I have a friend that will exchange work for a paint job (think I'm going dark blue) so I might stick with black interior. not sure yet. But I have no clue what would show up real nice. Shall I sand it or anything? (this is in the wrong thread, I know) thanks!
DC Dash can be put in an EF but it's a bitch as no bolts line up or anything. And also door panels will not fit with the DC dash in, every picture you see I bet they have no door panels.
Originally posted by klowndwarf
schwanginpt:
schwanginpt:
... her interior is blue right now.. so i found some paints that are actually dyes online that go on like paint but really get into the plastic and won't chip off very easily.. here's what i found:Viynlkote
this seems pretty good.... it needs to be sprayed on for best results, and you can give them a 1 X 1 swatch and they will match the color for your specific use.. its like 120 bucks for it.. but it says it will do most of an interior, which should be good for a CRX
the other is this:
Interior Spray
this is a spray can of primer and 2 cans of paint... you can't get custom colors.. just basic shades.. its a kit for like 50 bucks.. but you will prolly need 2 kits if you want to do the whole interior.
both methods just want you to have a clean surface.. shouldn't have to do any sanding.
so there you go!
good luck let me know what you go with
hey hazard666 you cant compare vw interchangability to honda. vw's you can change ANY part with most other vw with little or no modification. But as for the integra dash it would seem like more work than its worth besides the stock CRX dash is great and oh so nice.
btw latest vw golf was mrk 4 dont forget the potent Rabbit (golf mrk 1)
ColinT
ColinT
schwanginpt: thanks a lot, I like the second suggestion and will probably go with it, after i take care of the engine I'll start on the interior. I wanna try and have it done for the MD DC meet next month. It would be nicer at least
ill let you know and get some pics when i do it
