valve adjustment??????
Old Apr 4, 2003 | 03:04 PM
CRXtreme20's Avatar
CRXtreme20
Default valve adjustment??????
i need to find out what the valves should be adjusted to on a B16a1????? i know i need a special tool to do it but am not sure what they should be adjusted to ????? thanks in advance!
Old Apr 4, 2003 | 11:27 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
You're going to need a flat head screw driver, a 10mm box wrench and a feeler gauge. As for the specs, if I had my manual with me, I could help you out... Sorry.
Old Apr 5, 2003 | 10:09 AM
CRXtreme20's Avatar
CRXtreme20
yeah i got the feeler gauge but need the specs! does anybody know them???????
Old Apr 8, 2003 | 04:43 PM
AwwsChwA's Avatar
AwwsChwA
stock D16A6 specs are as follows:
.007-.009 inches intake
.009-.011 inches exhaust
Adjust them COLD. Allow the engine AT LEAST 6 hours to fully cool down, otherwise you'll have to go back and do it again. The torque on the adjusting nuts is 15 pounds, but you don't really need to torque em. Just get em good and snug, cuz if they're loose they'll back out (go ahead, ask me how I know ). Obviously, use common sense and don't put all your strength on em.
Valve cover nuts are torqued to 9 pounds. Oh, and just in case you don't know, coat the feeler gauge in oil before you use it.
