Attn: 1stGENcrx Exhaust Question
Banned
I heard that a full cat exhaust wouldn't be as good as just an axel back exhaust for my 91 crx si...?
whats u think? what do u have on ur rex?
not sure what a full cat exhaust you are talking about (full aftermarket exhaust with hi flow cat) or just a catback
1stgencrxer has a straight pipe with no cat basically on an 1st gen crx dx
as for the full exhaust (with cat) versus a stock exahust with stock cat with just an axleback you'll get more power b/c an axle back will do little when the stock exhaust before remains the bottle neck where a well designed full exhaust with hi flow cat would not have that problem
not sure what your source is but the d16a6 (2nd gen crx si) exhaust is restrictive
GWAKS- Tech Geekifier
It really depends on your mods, more than anything. It's illegal to remove a cat from a car that came with one from the factory, if that's a concern where you live, but typically you'll want to go up on piping diameter slightly when putting in a new exhaust.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
Banned
so a greedy xp(full cat back exhaust with a NEW catalytic converter) vs. just tenzo axel back. the Greedy winS? this kid who cliams to know a lot aboput crx's said something about crx's and older hatches need back pressure?? confused? let me know
pukimonster
yea, all cars need some backpressure in their exhausts. for a 1.6L, 2.0" to 2.25" would ideal piping size [diameter] because they flow more air than stock, but still have some backpressure.
therefore, the greddy full exhaust will pretty much beat out any axelback, because the stock piping is too restrictive.
is the kid that is saying "an axelback is better then a full exhaust" trying to sell an axelback system
No no no no no no no...
Back pressure is a side effect from reaching a reasonable compromise between maximizing exhaust velocity and CFM of exhaust. Engines do not "need" back pressure, it just happens that no exhaust possible will flow 100% of the exhaust an engine produces while simultaneously keeping exhaust velocity high for best scavenging effect, without generating some back pressure.
Back pressure impedes the flow of exhaust, and on a little four cylinder, you want to move the exhuast as efficiently as possible so that the maximum amount of fresh air/fuel mix possible is brought into the cylinder for combustion.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
I'd go ahead and get a full exhaust.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
