Header Sensor
Old Mar 24, 2003 | 11:45 AM
TYPE_CRXVTEC's Avatar
TYPE_CRXVTEC
Default Header Sensor
i GOT a b16a1 and i just bought a DC 4-2-2-1 HEADERS For 90-93 integra(thats what the shop Recomend). The DC Headers only have 1 plug for the Sensor. But on my stock b16a1 headers i have 2 plug sensor... my question is does it matter if I only plug one sensor in? or do i have the wrong HEADERS?
Old Mar 24, 2003 | 01:19 PM
WhiteRice's Avatar
WhiteRice
Do you have emissions where you are from? if not, no biggie. Otherwise, you'll have to weld on another O2 bung.
Old Mar 24, 2003 | 01:22 PM
CRXtreme20's Avatar
CRXtreme20
or just wire in the 2nd o2 sensor wires to the first sensor. meaning 2 sets of wires going to the same sensor.
Old Mar 24, 2003 | 01:30 PM
TYPE_CRXVTEC
Default thanx.
where can i get a 02bung at? what if i dont re wire the sensor?well i lose any HP?or pressure?
Old Mar 24, 2003 | 01:32 PM
CRXtreme20's Avatar
CRXtreme20
what vechile is this in?"???
Old Mar 24, 2003 | 01:33 PM
TYPE_CRXVTEC
A crx.
Old Mar 24, 2003 | 01:39 PM
CRXtreme20's Avatar
CRXtreme20
hf or si???? if hf did you use the hasport sub harness????
Old Mar 24, 2003 | 01:46 PM
TYPE_CRXVTEC
Default HF
its a HF and YEs i am using the wire harness from hasport.
Old Mar 24, 2003 | 02:03 PM
CRXtreme20's Avatar
CRXtreme20
i did the exact same thing. when you installed it did you hook the 2nd o2 sensor wires on the computer side???? if you did just dis-connect them. if not then your ok. the crx hf's only used one o2 from factory anyways so when the crx has a B16 with a DC haeder then you still use one o2.
Old Mar 24, 2003 | 02:12 PM
TYPE_CRXVTEC
Default so.
so i just need one sensor then?
