D16z6 question
Old Mar 12, 2003 | 02:46 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default D16z6 question
If i got a D16z6 head would it work on my D16a6 block? and if i got the 92-95 ECU would i have VTEC? or do i need to do something with my wire harness? please post!
Old Mar 12, 2003 | 02:56 PM
hybridhondahatch's Avatar
hybridhondahatch
for that added pep
basically your talking about a mini me swap. it will work with the pm6(a6) ECU but you'll have to have something to engage VTEC (shift light, VAFC, etc) and if you use the p28 (z6) youll need to do some wiring
Old Mar 12, 2003 | 03:02 PM
ZiviCase10287
RacinMasonC
how much do you THINK if i used my stock wiring with all that other stuff will cost? guesses please!
Old Mar 12, 2003 | 05:49 PM
hybridhondahatch
for that added pep
well if you use the si ECU and an autometer shift light it'll prolly be cheapest. i think the lights are like 80 bux and the pills (little chips w/ different RPM settings) for it are like 30 for 10 (they come in packs like 3000RPM-4000 RPM)
my buddy has one i'll see how much he wants for it if your interested but he only has the 8k-9k pill pack (used the shift light w/ his old b16)
Old Mar 13, 2003 | 03:32 PM
Speed Phreak's Avatar
Speed Phreak
Turbomafia
You could also use one of those RPM switchs from summit. They have selectable RPM engagement points and they only cost $50
Old Mar 13, 2003 | 06:13 PM
ZiviCase10287
RacinMasonC
so basically i HAVE to have something to engage the VTEC or else it won't work??? and if i did the shift light would it be on from when VTEC kicks in all the way to redline?
Old Mar 14, 2003 | 11:23 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
you guys forget that unless you have the correct ecu, or a vafc, you're not getting the correct fuel! That's spells disaster over time. Get a vafc, or at least a fields vtec controller. running the p28 is a pain, unless you get the obd1 plugs and do a ton of rewiring.
Old Apr 3, 2003 | 11:33 PM
MIRRAdekcpe's Avatar
MIRRAdekcpe
Default or
you can use the p28 ecu and get the Hasport conversion harness.
obd-0--obd-1, plug and play, basically, as far as the car will know, it WILL be obd-1.
and if you use the shift light on your tach, basically you're just using the shift light as an activation switch for vtec engagment. On a d16z, the factory vtec engagment is at 5500-5700rpm., so you set your shift light to come on at 5500rpm, as soon as the light comes on, so does vtec, BUT the shift light will stay on until redline, or until you shift. I wouldn't use this method though, i would just use the p28ecu and get the Hasport conversion harness. You won't have a blaring light on all the time, and also it will probably run alittle better, it will run like its supposed too.
