wondering bout engine swap
Old Mar 9, 2003 | 04:51 PM
adam's Avatar
adam
Default wondering bout engine swap
Hey, i have a 1985 crx its in good running condition but for one problem. the bearing in the axil is stripped and i think i need to replace the axil, for one how much will this cost? Another ? is i was wondering if i can engine swap a b-16a into a yr. 85 crx. plz help me out, this is my first car and i know very little, thanx.
-adam-
Old Mar 9, 2003 | 04:53 PM
bambbrose's Avatar
bambbrose
I think hasport has a kit for putting a b series engine into a 84-87 civic/crx. not sure though
www.hasport.com
Old Mar 9, 2003 | 04:56 PM
bambbrose's Avatar
bambbrose
yea, they do, it costs $650 bucks though.
here is the exact link
http://www.hasport.com/Products/Moun...unt%20AFB1.htm
Old Mar 9, 2003 | 06:05 PM
jaje's Avatar
jaje
HC Racer H5
depends on what model 1g crx you have...putting a b16 into requires the conversion over to multiport fuel injection if you don't have the Si model
Old Mar 9, 2003 | 06:45 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
It's Axle not Axil.
Old Mar 9, 2003 | 06:55 PM
WhiteRice's Avatar
WhiteRice
If you know very little, you should go ahead and purchase a manual (chiltons/helms/etc) for the car you have. Then you'll have that to read up on. Then also buy a manual for whichever engine you decide to toss in. Just an idea. Hope that doesnt' sound like I'm being a thingy head...just trying to help you out!
Old Mar 9, 2003 | 09:01 PM
Kai's Avatar
Kai
Rotorphile.
Default Re: wondering bout engine swap
The last axle I had to replace (1986 Accord LXi, passenger side) only cost $50+core for a rebuilt unit. The only problem I had was a frozen suspension fork-LCA bolt which required a new LCA ($115), suspension fork-LCA bolt ($8), and nut for the aforentioned bolt ($3). After I aquired all the parts and a few more tools (32mm impact socket, ball joint puller) I had it together in about an hour.
Just don't forget to replace the cotter pins like "some people":exnbp:
