87 crx
Old Feb 22, 2003 | 09:17 AM
misterq14's Avatar
misterq14
Default 87 crx
can the body pieces(front bumper,side fender.....) from a 88-91 crx fit onto a 87 crx without any problems. also what kind of engine will fit in the 87 crx.
Old Feb 22, 2003 | 05:29 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
Default Re: 87 crx
No.
A D16A1 from the 1986-89 Integra with the Integra tranny basically bolts in if you have an Si. A carbureted car will need to be converted to fuel injection first. You can also use the early JDM ZC. There was even a carbureted ZC, if you can find one.
Old Feb 22, 2003 | 07:06 PM
Kai's Avatar
Kai
Rotorphile.
Default Re: Re: 87 crx
"Browntop" ZC's, identifiable by vacuum advance distributors and the namesake brown valve cover. These are very hard to find at importer's shops, but they are around, I promise.
Old Mar 9, 2003 | 02:03 PM
DC294GSR's Avatar
DC294GSR
How did I get here?
is it possible to put a B16 into a 87?..anything annoyingly complicated? anyone done it?
Old Mar 9, 2003 | 05:12 PM
Gasoline Fumes
HASport makes a mount kit for putting the B16 into these cars.
Old Mar 9, 2003 | 06:31 PM
spdzone's Avatar
spdzone
if you have a DX you'll have some trouble. mainly because the car is carbureted and everything from the gas tank forward is different because of the engine you plan to put in is fuel injected. i read somewhere that you can avoid having to strip all the lines out by buying a Motec computer. i have an 85 DX and planning to do this next year.
my friend had an 87 Si and we did a ZC swap over a weekend about 2 years ago.
Old Mar 9, 2003 | 06:35 PM
DC294GSR's Avatar
DC294GSR
How did I get here?
so an 87 Si should be easier then?? i dont have a CRX, im just considering it as a project for this summer.
Old Mar 9, 2003 | 08:49 PM
Kai's Avatar
Kai
Rotorphile.
Any 85-87 CRX Si or 86-87 Civic Si will be easier to convert then the other 84-87 carb'd models.
FC's and 3rd gen Civics... you have good taste
Old Mar 10, 2003 | 06:25 AM
DC294GSR's Avatar
DC294GSR
How did I get here?
haha thanks. im a sucker for the old school.
Old Mar 10, 2003 | 03:57 PM
87crxSI's Avatar
87crxSI
Default d16a1
Hi i was wondering if there is any modifications i have to do to but that d16a1 into a 1987 crx si. i already have the old engine out and started rebuilding it. I am considering putting that engine in beacause of the performance options. Thanx
Jayson
