can anyone help
I put in a MSD coil blaster 2 and nolagy spark plug wires on my 86 crx si and when I hooked the neg. cable to battery it blow a 55a fuse under the hood. I guess I wired the coil wrong. Does anybody know how to wire the coil blaster?
wire the coil to the wires on the internal coil of the dizzy
Originally Posted by marvinp8700
(Post 4414789)
Thats what I did, but i used a MSD resister and I put in nology spark plug wires and the wires have ground cable. I ground them to the valve cover. I also put ground kit and volteg stabalizer. they have been for a year now and no problems. I don't know if any of those things could be confliting each other or maby I don't need the resister? If you can help
Thanks ew4 |
What fuze you blowin
Do you have the ground kit and stabilizer kit in?? I don't think you need the resistor in my B20 I didn't use the resistor same as my 89 DX
