Need help/advice H22 swap into a CRX
Old Jul 20, 2009 | 01:24 PM
CReX driver's Avatar
CReX driver
Default Need help/advice H22 swap into a CRX
I need some advice, specs whatever help anyone can give me. I'm putting an H22 into my 91 CRX Hf. At $300 with only 89K miles I can't pass on the engine with harness and CPU. But I'm not sure where to turn for specs on engine mounts and such could anyone out there assist? This is the way I wanted to go but thought money was going to keep me back but like I said $300 is a killer deal and frees me up to spend a little extra in other areas. Please please any help would be great
Old Jul 21, 2009 | 07:06 AM
jlicrx's Avatar
jlicrx
http://hasport.com/tech/installs/efh1.pdf
http://www.explicitspeedperformance....H22AHowTo.html
Old Jul 21, 2009 | 02:12 PM
CReX driver
Thanks for the links, I appreciate it.
Old Jan 2, 2010 | 11:41 AM
madmaxH22crx's Avatar
madmaxH22crx
you will need full shifter set up from a accord with F22 or a pralude with H22 or H23 lots of wiring and a ton of other work it is a rough swap. I'm about 80% finished with mine now so if you need any help feel free to txt me i can give you all the info you need m8y n0u3m9b8e1r 3i5s34
Old Jan 2, 2010 | 12:18 PM
madmaxH22crx
Old Jan 18, 2010 | 03:12 PM
greasemonkey89's Avatar
greasemonkey89
Your neighborhood Greaser
explicitspeed like mentioned above is a awesome shop with many things to offer for the h22 swap in a crx. look into there mounts and traction bar deal this can be a cheap process as long as you stay with a h22 or f22 transmission. so far mfactory is starting to produce gears for the h-transmission folks.
