question about 4th gens, help plz :)
Old Feb 2, 2003 | 06:55 PM
spanky's Avatar
spanky
I go duffy on dem bitches
Default question about 4th gens, help plz :)
as most of you know im about to buy a 91 civic ex sedan.
i was going to go D16Z6 turbo, but ive recently been offered an 87 CRX with a B18A1 swap for a very good price.
will i be able to use the mounts i have between both cars to swap the B18A1 into the sedan, and also will i be able to swap the suspension (for the rear brakes) onto the sedan?
if not a direct bolt on, what would i need to do these two things?
any help is appreciated
Old Feb 2, 2003 | 06:58 PM
crucial Si's Avatar
crucial Si
Banned
damn, im stumped, i really dont know 4thgens but damn...good questions....
Old Feb 2, 2003 | 07:17 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
3rd gen B series mounts are not the same as 4th gen mounts. The most you'd be able to use is the engine and tranny.
As you've probably noticed also, there isn't a lot of room under the hood of a first gen CRX when there's a B-series stuffed in there, so your options are limited if you don't want to hack up a car and decide to maybe keep it.
-Harry
AIM: NDcissive
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
No the 3G Civic/1G CRX have different mounts than the 4G Civic/2G CRX, so it will not be direct drop in. However all you would really need are some 4G b-series mounts and you would be good to go for getting it in the car. And you can't swap the rear discs from the CRX because it has a solid beam rear axel and the Sedan would have independent rear so none of it is the same.
But why not just buy the CRX and fix that up? Its lighter than a sedan and it already has the engine in it.
Old Feb 2, 2003 | 07:20 PM
1stGenCRXer
First gen CRX's do not have disk brakes in the rear standard. The only rear disks that would be found would be from a first gen teg.
-Harry
AIM: NDcissive
Old Feb 2, 2003 | 07:22 PM
FourthGenHatch
So either way hes not getting them on there.
Old Feb 3, 2003 | 03:03 AM
spanky's Avatar
spanky
will i be able to use the axles, ecu and shfit linkage from the crx?
Old Feb 3, 2003 | 04:16 AM
1stGenCRXer
Axles no, ECU yes, shift linkage not sure.
-Harry
AIM: NDcissive
Old Feb 3, 2003 | 04:19 AM
spanky's Avatar
spanky
then ill need axles from a 92-93 integra, right? or a 90-91? shift linkage from that car also, i would assume...
Old Feb 3, 2003 | 05:15 AM
FourthGenHatch
I would think 90-93 Integra Axels would all be the same. I think you use them. Sometimes you need different intermediate shafts and I'm not sure what those are exactly.
For the linkage you can cut the Sedan's and weld it together. Or order a pre-fab one from HASport.
