Check Engine light
Old Dec 29, 2002 | 08:42 AM
Ryousuke Takahashi's Avatar
Ryousuke Takahashi
4G4D shortly a beast
Default Check Engine light
here's the problem the light comes on about 2-3 minutes after i start driving but the oil light and the tempertaure gauges stay at regular intervals what's going on it just comes on for no reason.
Old Dec 29, 2002 | 08:57 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Check the codes and fix accordingly. Just pull up the carpet on the pass. side, and count the flashes. Long flash is the tens place, shorts are the one place.
Old Dec 29, 2002 | 02:17 PM
all motor 91ef's Avatar
all motor 91ef
USDM spec
Mines did that for awhile, until i replaced the O2 sensor with a new, so you might have to give that a try.Hope that helps
Old Dec 29, 2002 | 04:36 PM
Ryousuke Takahashi
im confuse i thought they were on the drivers side
Old Dec 29, 2002 | 07:44 PM
WhiteRice's Avatar
WhiteRice
Thought what was on the drivers side? :dunno:
Old Dec 29, 2002 | 09:45 PM
Kai's Avatar
Kai
Rotorphile.
The ECU.
Anyway Takahashi, we can help you better if you read the code and post it here.
Old Jan 5, 2003 | 06:17 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
mine did that too, its the o2 sensor, fix it now!! or else you'll be burning rich!!!
Old Jan 7, 2003 | 10:22 AM
Ryousuke Takahashi
well i finally broke down and took it to honda and they said it was the programmed fuel injection so i have to pay them $200 and i get my car back today.
Old Jan 7, 2003 | 10:33 AM
WhiteRice's Avatar
WhiteRice
So what did they say specifically was wrong w/it?? A sensor?
Old Jan 7, 2003 | 10:59 AM
Kai's Avatar
Kai
Rotorphile.
Well, that's obvious if the CEL was on, Honda employees don't give "civilians" much credit. You better ask them for a better explination to justify $200!
