starting up engine problem
Old Dec 11, 2008 | 10:28 PM
mIeNsTa's Avatar
mIeNsTa
Default starting up engine problem
hey guys i own a 91 civic hatch and everything i start it up it seems to die the only time it will stay on is when i have my feet on the gas but right when i let my feet off the gas it dies can anyone help me????????
Old Dec 12, 2008 | 10:04 AM
gingas's Avatar
gingas
Sounds like a bad alternator. Is it a DX or SI. When you mean everything you start up it dies. Are you meaning lights etc.. See if you can get it towed to dealer or some shop to have checked out.
Good luck & post what problem was..
Old Dec 12, 2008 | 08:59 PM
mIeNsTa's Avatar
mIeNsTa
update.....i was VERYYYYYY low on oil so when i added oil everything started back up but i have 3 codes flashing on my ecu code 10,14 and,16 any help with the codes???thanks alot guyss
Old Dec 14, 2008 | 09:44 PM
TRLMech's Avatar
TRLMech
Sounds like you have a defective IAC valve, replace that first, should be ok after
Old Dec 15, 2008 | 01:52 AM
mIeNsTa's Avatar
mIeNsTa
where is my IAC located at?? i cant find it lol thanks guys
Old Dec 23, 2008 | 02:10 AM
TRLMech's Avatar
TRLMech
Should be on the intake manifold right on the back of it, or on the back drivers side of the intake manifold. I can't remember, been awhile since i had a stock motor. Either way it's on the intake manifold, don't mistake the throttle position sensor for it.
Old Dec 26, 2008 | 11:43 PM
mIeNsTa's Avatar
mIeNsTa
alright ill make sure to take a look at it thanks guys
