Quick question ?????????
Old Dec 23, 2002 | 06:51 PM
Ryousuke Takahashi's Avatar
Ryousuke Takahashi
4G4D shortly a beast
Default Quick question ?????????
what year would the Ls vtec motor be and about how much would you need to do a full swap.
Old Dec 23, 2002 | 07:45 PM
HappySnatch's Avatar
HappySnatch
OG
Default Re: Quick question ?????????
the setup would depend on how much you're willing to spend. an ls vtec just consists of an ls bottom & vtec head. as far as building the motor, you could use stock oem parts or use aftermarket internals. some ls vtecs will run 14s, others will run 11s.
Old Dec 23, 2002 | 08:04 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Well they started in 1990 I guess with the first B18 Integras. 90-91 was ODB-O, 92-93 was ODB-1. After that was B18Bs I think which are probably ODB-2. The head can come from any VTEC B-series like the B16A, B18C (GSR or Type-R). I think, not positive. But you have to use certain internals to make it work right.
Old Jun 1, 2003 | 11:05 PM
deadlock2k1's Avatar
deadlock2k1
hmm ok. i am new to the ls idea. what bottom end do u use then? and would the b18c head be better then the b16 series v tec head? and whats so great about the ls v tec that can bring them to 11s?
Old Jun 1, 2003 | 11:39 PM
brtecson's Avatar
brtecson
pukimonster
the b16 head flows better than the gsr head. i'm not sure on the exacty details of why/how this is, but that is the general idea.
the lsvtec's that are powerful enough to go 11s usually have P&P done and have 13:1 compression, with a gutted interior and drag slicks. or lsvtec turbo could put a car into the 11s
Old Jun 2, 2003 | 06:25 AM
crxb16er's Avatar
crxb16er
yah ur just starting with ur ls nonvtec engine and putting on a vtec head, not sure exactly what bottom ends u can use and what heads u put on, do a search, my friend had a base model 99 integra and put a vtec head on his car and the gain is pretty good for the buck.
Old Jun 2, 2003 | 08:39 AM
Kai's Avatar
Kai
Rotorphile.
Ok, short and sweet.
Potential blocks ("bottom ends"):
B18A (90-93 Integra)
B18B (94-01 Integra)
Potential heads ("top ends")
PR3 (B16A Si-R, B17A GS-R)
PR3 (B18C Type R, B18C5)
P72 (B18C Si-G, B18C1 GS-R)
Then you ream some holes, run a new oil line, and more modifications depending on how high you want to rev it.
The LS/VTEC hybrid is not generally considered a "noob" engine because it must be custom built depending on application.
Old Jun 2, 2003 | 01:49 PM
deadlock2k1
hmm sounds to hard fo rme.. but an inquiring mind must know... how would you go about with the oil lines and etc.. i mean i have heard its almost bolt on..(the head to the bottom end from different models)
Old Jun 2, 2003 | 01:54 PM
deadlock2k1
oh and what does ls stand for?
Old Jun 2, 2003 | 02:00 PM
crxb16er's Avatar
crxb16er
its just the base model integra ls gsr and type r are the different ones u can get
