Help w/E-Brake
Old Dec 4, 2002 | 02:29 PM
WhiteRice's Avatar
WhiteRice
Default Help w/E-Brake
When I got home from work today, my ebrake woudln't lock like it is supposed to. when I pull it up, it brakes, but won't lock. Any suggestions? TIA.
Old Dec 4, 2002 | 02:41 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Is the button stuck, or the spring broke/out of place? You may just need to lube the moving parts.
-Harry
AIM: NDcissive
Old Dec 4, 2002 | 03:20 PM
Guest
Guest
Posts: n/a
bring a log with you to block the wheel just in case it rolls
Old Dec 4, 2002 | 04:41 PM
SI Addiction's Avatar
SI Addiction
i think u should check the rachet system for n e errors
Old Dec 4, 2002 | 05:07 PM
RiGhTeOuS ReX's Avatar
RiGhTeOuS ReX
i agree i think i could be the locking system good bad
Old Dec 4, 2002 | 05:17 PM
WhiteRice's Avatar
WhiteRice
I'll check it out when it's light out.....and maybe a little warmer. Thanks for the suggestions guys.
Old Dec 5, 2002 | 10:22 AM
WhiteRice's Avatar
WhiteRice
Got home from work, ebrake didn't work.
Got to work this AM, still not working.
Went to lunch...STILL not working. Each time I'm hitting and banging on the button and handle.
Got back to work after lunch....it worked. WEIRD!!! I didn't even hit it or anything this time. Maybe if I'm nicer it'll respond better!!!! Weird!!!
Old Dec 5, 2002 | 10:49 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
sounds like it's not liking the cold. Should just need to lube it up. YOu can work the handle off by twisting it, but I'd go after the ratchet part underneith. Just takes a few minutes to get in there.
