uh oh need help!!
Old Nov 27, 2002 | 07:17 PM
bullfrogcrx90's Avatar
bullfrogcrx90
Default uh oh need help!!
hey guys my rex is fine and dandy but now when i come to a stop the car revs it self just alittle but it does it all the time.....
Old Nov 27, 2002 | 07:20 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Adjust your idle screw back down.
Old Nov 28, 2002 | 08:44 AM
Guest
Guest
Posts: n/a
take out the hazard fuse, and put it back on 10 mins
Old Nov 28, 2002 | 10:40 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Neither of those solutions solve the revving. You either have a vaccum leak, or you have a gunked up EACV or Cold idle valve. You could also have a bad gasket on yout TB or intake manifold. To solve the problem permanently, you have to eliminate the cause. Resetting the ecu MAY get rid of it for a few days, maybe even moneths, but it will come back. Track down the leak, and you're good to go.
Old Dec 3, 2002 | 03:55 AM
schwanginpt's Avatar
schwanginpt
Nadene will Return
how high is it revving when you stop?? The white DX i had was doing that for a while.. started revving to about 1200-1500 and after a while it started going to like 3K!! if i smacked the throttle a couple times i could get it down to idle... anyway.. im blabbing If it sounds anything like that.. its the O2 sensor.
Old Dec 3, 2002 | 04:40 AM
lithium5's Avatar
lithium5
jo3
i have no clue...:bigok:
Old Dec 7, 2002 | 04:04 AM
Old91CivicGuy's Avatar
Old91CivicGuy
I agree. Car thinks there is too much o2 so it dumps in more gas. intake gasket is probably the cause. If it was a hose, your car would studda.
Old Dec 7, 2002 | 03:57 PM
jdmcrx's Avatar
jdmcrx
bullfrog crx this is my first time on here...I have a ? what did you get that is bullfrog cam/head/tb...and what kind of performance did you get?
Old Dec 8, 2002 | 08:07 AM
RiGhTeOuS ReX's Avatar
RiGhTeOuS ReX
yeah what do u have on ur car?
