Front brakes overheating....Need help
Old Aug 14, 2008 | 02:40 PM
xxdrkomnxx's Avatar
xxdrkomnxx
Dark OMens
Default Front brakes overheating....Need help
I own a 91' Honda CRX. My front driver side brakes have been sticking for the last few months and have gone to get them replaced but the problem always comes back. Have replaced the calipers and brake lines but the problem has come back. Can someone please help me
Old Aug 14, 2008 | 10:27 PM
ChrisS's Avatar
ChrisS
Warped brake disk?
(have the shop check the runout on your front driver-side brake disk)
Take Care,
ChrisS
Old Aug 15, 2008 | 03:08 AM
xxdrkomnxx's Avatar
xxdrkomnxx
Dark OMens
getting car checked out today, hopefully thats all it is.
Old Aug 15, 2008 | 11:50 PM
TRLMech's Avatar
TRLMech
Default Possibly the brake master cylinder?
Also check the brake pedal return spring, if it has one, not sure, if the brake pedal is not returning to the full up position, the brake fluid cannot return to the reservoir and thus cause your calipers to stick, especially when the brake fluid expands.
Old Aug 28, 2008 | 09:43 AM
EJason's Avatar
EJason
Any noises at all? Could be your heat shield rubbing on the rotor?
Old Sep 9, 2008 | 10:49 PM
Spec R's Avatar
Spec R
this also happens when the seals go bad in your brake master cylinder. it happened in my 240sx. replaced the bmc and it went away.
DB Squad
Integra Forum Moderator
Old Sep 10, 2008 | 05:27 AM
93 ITR's Avatar
93 ITR
Grease Monkey
also try to get the hub check up if thats not level right it can cause problems. just do a runout on that too.
