86 hf suspension
Old Nov 20, 2002 | 09:00 PM
mcdisco420's Avatar
mcdisco420
Default 86 hf suspension
i put 17" rims on my crx, and now im worried that i might break something. everything is so small and chinzy looking, and the hf has these tiny little solid discs up front that r not up to the task of slowing 17" wheels from anything near high performance driving. can i use some si or integra pieces to beef up the frontend a bit???? is there a low buck big braje upgrade??????whats the biggest tire that can fit on my car with 16" rims???????? the 17's are only temporary, and i will be getting 16's to replace them.
please let me know all u can. thanks.
Old Nov 21, 2002 | 05:44 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
First off.... even 16's are too big....
The suspension will cope with the big wheels, but as you discovered, the brakes and clutch are not...
With 16's, about the largest tire you could put on would be 185's or 195's in a low profile. Using say... 14's you could run 215 45's just as easy and they would be cheaper.
You can swap over teg brakes with little to no trouble, rear disks take a little bit more time.
Besides that... if you have the stock HF drivetrain in it, I imagine you aren't getting very good performance to start with....
-Harry
AIM: NDcissive
Old Nov 21, 2002 | 08:10 PM
mcdisco420's Avatar
mcdisco420
Default sloasscrx
i have finally made up my mind about this car. it runs great the way it is, but it is really slow. but i can deal with that, if it looks good.
can u give me more info about the brake swap? what would be involved and what parts would be needed from the teg?
Old Nov 22, 2002 | 05:12 AM
1stGenCRXer
Default Re: sloasscrx
http://www.redpepperracing.com/forum...t=ST;f=2;t=648
Old Nov 24, 2002 | 08:29 AM
87Hybrid's Avatar
87Hybrid
I have the complete reat setup and master cylinder, proportioning valve from an 88 Integra if you are interested E-mail me at 87Hy6brid@attbi.com It shouldnt cost too much to ship the whole set by greyhound bus. I got pics of everything if you want.
