idle fluctuation
Old Nov 9, 2002 | 04:28 AM
excitid's Avatar
excitid
Default idle fluctuation
Ok I know this has been covered before but my car is idling from 800 to 1500 over and over whenever I come to a stop. I unplugged the tps and it stopped but when I plug it in it eventually starts up again.
Old Nov 9, 2002 | 05:08 AM
WhiteRice's Avatar
WhiteRice
I"ve never done this personally, but have read it works. Wait till your car warms. Unscrew your idle bolt on the back of the Intake manifold. Unscrew it all the way, but don't pull it out. Then screw it back in. do this 2-3 times and set it where you want the idle. Like I said, I've never done this, but read it works.
I've also heard clean the TB and that'll help some too.
Old Nov 11, 2002 | 08:27 AM
mullinator's Avatar
mullinator
Could also be air in your coolant lines. -scott
Old Nov 11, 2002 | 08:41 AM
WhiteRice's Avatar
WhiteRice
I've heard of this causing the temp gauge to rise, but not mess w/the idle.
But, if it does, the cure would be to take off the radiator cap (when the car is cold), and let it run for about 10-15 mins. Make sure you're on a flat area as well!!!
Old Nov 11, 2002 | 08:49 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
heres a funny story.
i changed my girls rad in our old 90 hatchback last year when it was still her daily.
the gd thing kept overheating though, couldnt figure out why...
drive it around the block, it would get blazing hot, bring it home, drive on ramps, check the coolant...coolants fine.
take it off the ramps, drive it around....
put it on the ramps, take it off :doh:
fill the car while on level surface? problem solved :doh: :doh:
Old Nov 11, 2002 | 09:03 AM
WhiteRice's Avatar
WhiteRice
DOH!!!!! hahaha
Old Nov 11, 2002 | 10:20 AM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Pull off your negative battery cable and let the ECU reset. That will fix it sometimes.
Old Nov 12, 2002 | 07:28 AM
Fujiwara Takumi
It's my first day.
civic has vacuum lines right? i wonder if one is knocked off.
Old Nov 16, 2007 | 10:05 AM
dgresham2134's Avatar
dgresham2134
I am having the same issue with my 92 accord. Did you ever get your problem solved? If so, what did you do??????
