temp gauge sending unit
Old Apr 24, 2008 | 03:22 PM
import4life's Avatar
import4life
Default temp gauge sending unit
where is the temp. sending unit cause i got the temp pod and i need to hook it up cause my gauges dont work
Old Apr 24, 2008 | 06:11 PM
jlicrx's Avatar
jlicrx
on the end of the head below the distributor - has 1-wire connector with yellow with green stripe wire - depending on what gauge you have, you may need to change the sending unit for one that is compatible with the gauge
Old Aug 16, 2008 | 12:37 AM
TRLMech's Avatar
TRLMech
What motor you got, some older B series motors and the D series motors have the sending unit on the back of the engine near the oil pressure sender. (near the oil filter)
Old Aug 16, 2008 | 08:53 AM
jlicrx's Avatar
jlicrx
that is not the gauge sending unit on the back of the block - that is the cooling fan switch
Old Aug 19, 2008 | 12:24 AM
TRLMech's Avatar
TRLMech
Oh yeah, you're right, then it is the one under the distributor.
Old Aug 19, 2008 | 01:02 AM
A-series's Avatar
A-series
v-card member alpha
There may be two such things under the distributor, one which looks like the thermoswitch (cooling fan switch) and a smaller one (the temp gauge sending unit) that you can disconnect simply by pulling on the connector, whereas the thermoswitch or it's "twin" (which sends to the ECU I believe, forget the name) have a connector that will click and lock into place.
Here's a pic, I forgot about taking this h:
From my '92 Civic
For my car, the service manual says 7ft-lbs. for the temp. gauge sending unit, and to use liquid gasket on the threads.
