making ecu jumper ?
Old Feb 1, 2008 | 01:14 PM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
Default making ecu jumper ?
what do i do with pin b1, b1 goes to a25 and a25 goes to obd0 a13 and o2 black under green. anyone have pics of what it looks like?
Old Feb 1, 2008 | 02:02 PM
jlicrx's Avatar
jlicrx
OBD0 pins on left - OBD1 pins on right
A Plug:
A1 (yel) -> A2 (yel) Injector 4
A2 (blk) -> A23 (blk) Power Ground 1
A3 (yel) -> (unused) *
A4 (blk) -> A24 (blk) Power Ground 2
A5 (red) -> A3 (red) Injector 2
A6 (grn) -> A20 (red) Evaporative Purge Valve
A7 (red) -> (unused) *
A11 (blu/yel) -> A9 (grn/wht) IACV
A12 (grn/blk) -> A7 (grn/yel) Fuel Pump Control 1
A13 (yel/blk) -> A25 (yel/blk) ECU Power 1
A14 (grn/blk) -> A8 (grn/yel) Fuel Pump Control 2
A15 (yel/blk) -> B1 (yel/blk) ECU Power 2
A16 (brn/blk) -> B2 (brn/blk) Logic Ground 2
A17 (blk/yel) -> (unused)
A18 (blk/red) -> A26 (blk/red) Logic Ground 1
* Unused injector wires. If you are making an adaptor harness, there is nothing to be concerned with. If you are cutting the old plugs and using new ones, you can tape them and set them to the side. Or you can make the connection above the split for a cleaner install.
B Plug:
B1 (wht/grn) -> D1 (wht/blu) ECU Memory
B2 (orn) -> A6 (orn/blk) Oxygen Sensor Heater Control **
B3 (yel) -> A15 (blk/red) A/C Clutch Relay
B4 (yel/grn) -> A12 (yel/grn) Cooling Fans
B5 (wht/yel) -> A16 (wht/yel) Alternator
B6 (grn/orn) -> A13 (grn/orn) MIL (Check Engine Light)
B8 (blu/red) -> B5 (blu/red) A/C switch
B13 (blu/wht) -> B9 (blu/wht) Starter Signal
B14 (blu) -> D9 (pink) Alternator
B15 (wht) -> A21 (red/grn) Ignitor 1
B16 (yel/red) - B10 (yel/blu) VSS (Speed Sensor)
B17 (wht) -> A22 (red/grn) Ignitor 2
B19 (grn/red) -> D10 (grn/red) ELD (Electric Load Detector)
B20 (brn) -> D4 (brn) Service Check Connector ***
C Plug:
C1 (orn) -> B11 (orn) CYP P
C2 (wht) -> B12 (wht) CYP M
C3 (orn/blu) -> B13 (orn/blu) TDC P
C4 (wht/blu) -> B14 (wht/blu) TDC M
C5 (red/yel) -> D15 (red/yel) IAT (Intake Air Temperature) Sensor
C6 (red/wht) -> D13 (red/wht) CTS (Coolant Temperature Sensor)
C7 (red/blu) -> D11 (pink/blk) TPS Output
C9 (red/wht) -> (unused)
C10 (grn/wht) -> D2 (grn/wht) Brake Signal
C11 (wht) -> D17 (wht) -> MAP Output
C12 (grn/wht) -> D22 (grn/wht) Sensor Ground
C13 (yel/wht) -> D20 (yel/wht) Sensor Power
C14 (grn/wht) -> D21 (grn/wht) MAP Ground
C15 (yel/red) -> D19 (yel/grn) MAP Power
C16 (wht) -> D14 (wht) Oxygen Sensor Output
Added Wires (Pins are, of course, on 1992-1995 plugs):
A4 (orn/wht) -> VTEC Solenoid
D3 (white) -> knock sensor ****
D6 (orn/blu) -> VTEC Pressure Switch
B15 (blu/grn) -> CKP P ****
B16 (blu/yel) -> CKP M ****
Old Feb 1, 2008 | 03:12 PM
90_crx_flaze
Drift King
thanks mr zcspeed lol
Old Feb 1, 2008 | 04:29 PM
90_crx_flaze
Drift King
is this one wrong?
Obd0 to Obd1 wiring harness.
53 to 45 pins. + 4
A - 18
B - 11
| pin_id | wire_color | pin_function | pin_name | 4G (pr3 pin)
| A1 | BRN | INJ1 | INJ1 | -> A1
| A2 | YEL | INJ4 | INJ4 | -> A7
| A3 | RED | INJ2 | INJ2 | -> A3
| A4 | GRN/YEL | VTS | VTEC solenoid | -> ADD -> vtec selenoid
| A5 | BLU | INJ3 | INJ3 | -> A5
| A6 | ORN/BLK | PO2SHTC | O2 sensor (heating element) | -> ADD [o2 heater control ->blk (under wht wire)]
| A7 | GRN/BLU | FLR1 | fuel pump (main relay) | -> A12
| A9 | BLK/BLU | IACV | IAC valve | -> A11
| A12 | GRN | FANC | engine coolant temp switch | -> B4
| A13 | GRN/ORN | MIL | MIL (check engine light) | -> B6
| A15 | BLK/RED | ACC | (a/c compressor clutch) | -> B3
| A16 | WHT/GRN | ALT C | alternator | -> B5
| A20 | RED | PCS | EVAP purge control solenoid | -> A6
| A21 | YEL/GRN | ICM | ICM | -> B15
| A23 | BLK | PG1 | ground *(main relay ground) | -> A2
| A24 | BLK | PG2 | ground *(main relay ground) | -> A4
| A25 | YEL/BLK | IGP2 | to main relay and to gound for o | -> A13 [splice for o2 -> blk (under grn)]
| A26 | BRN/BLK | LG1 | gound | -> A18
| B1 | YEL/BLK | IGP2 | to pin A25 | -> A15
| B2 | BRN/BLK | LG2 | ground to shields for CYP & TDC | -> A16
| B5 | BLU/RED | ACS | a/c switch | -> B8
| B9 | BLU/WHT | | starter signal | -> B13
| B10 | ORN | VSS | vehicle speed sensor | -> B16
| B11 | ORN | CYP P | CYP -P | -> B10
| B12 | WHT | CYP M | CYP -M | -> B12
| B13 | ORN/BLU | TDC P | TDC -P | -> C3
| B14 | WHT/BLU | TDC M | TDC -M | -> C4
| B15 | BLU/GRN | CKP P | CKP -P | -> C1
| B16 | BLU/YEL | CKP M | CKP -M | -> C2
| D1 | WHT/BLU | VBU | Back Up Power | -> B1
| D2 | GRN/WHT | BKSW | brake switch | -> C10
| D3 | | KS | Knock Sensor | -> ADD -> Knock sensor
| D4 | BRN/WHT | SCS | service check connector | -> mil [toggle switch with ground]
| D6 | BLU/BLK | VTM | VTEC pressure switch | -> ADD -> vtec pressure switch
| D9 | WHT/RED | ALT F | alternator | -> B14
| D10 | GRN/RED | ELD | electric load detector | -> B19
| D11 | RED/BLK | TPS | TPS Signal | -> C7
| D13 | RED/WHT | ECT | ECT sensor | -> C6
| D14 | WHT/RED | PHO2S | O2 sensor | -> C16 [splice for o2 -> wht]
| D15 | RED/YEL | IAT | IAT sensor | -> C5
| D17 | WHT/YEL | MAP | Map Signal | -> C11
| D19 | YEL/WHT | VCC1 | MAP 5V | -> C15
| D20 | YEL/BLU | VCC2 | TPS 5V | -> C13
| D21 | GRN/WHT | SG1 | MAP GND | -> C14
| D22 | GRN/BLU | SG2 | TPS GND | -> C12 [splice for o2 -> grn]
Old Feb 2, 2008 | 07:27 AM
jlicrx's Avatar
jlicrx
Originally Posted by 90_crx_flaze
is this one wrong?
they are essentially the same - the only difference is that the one i posted is for converting a stock DX harness (one that hasn't been converted to MPFI) to OBD1 and MPFI at the same time - the one you posted is for converting a stock OBD0 MPFI (or already MPFI converted DX) harness to OBD1 - the one i posted has the OBD0 pins on the left and the one you posted has the OBD1 pins on the left
Old Feb 2, 2008 | 05:41 PM
90_crx_flaze
Drift King
oh okay, i dont have anything that is dual point, i already had the multi point swap its a cake swap, do i have to run a crank sensor, that is next to the crank pulley?
Old Feb 3, 2008 | 01:31 PM
90_crx_flaze
Drift King
what about OBD1 pin D4 one says to toggle switch to ground and the other says ->OBD0 pin B20?
