Gas Leak!!!On Line
well i went to start car and seen gas coming out of a line. here is a pic of the line to the fuel filter but its the end to the fuel rail. can i cut the hose and add new or do i have to buy all new?
its leaking from the line and the metal line to the fuel rail by the regulator i think thats what its called here is a pic ill circle it..car project2 001ccc.JPG
if it is leaking on the line, like where the rubber hose goes into the metal piece on the banjo fitting, you will need a different hose - this is a high pressure hose and there isn't any way to fix it - that part on the end of the fuel rail is a pulsation damper - it screws into the end of the fuel rail - the banjo fitting on the end of the fuel line is sandwiched between the rail and the damper - it has a gasket between the damper and the banjo fitting on one side and a brass crush washer between the banjo fitting and the fuel rail on the other side - if it is just leaking there, you could first try tightening the pulsation damper a little (don't break it) - if that doesn't stop the leak, remove the damper and install a new gasket and washer
here is the par its coming from, when i just turn the key over it runs out im thinking the top part not sure its hard to tell. but i might be able to video it if that would help you?car hose dis 002.jpg
Have somebody turn the key to prime the pump while you're looking to see exactly where the leak is. Nobody here can tell you where it's leaking from. Replace the hose that's leaking or whatever you need to do like jlicrx said.
