upper lower strut bar f/b install
AARRGGHHHH
I purchased a complete set of skunk2 upper and lower tower strut bars. I need help in figuring out where they go on my car. If jacking the car up is necessary, where is the best center point to use? Pictures of anyone else's install would be helpful. It appears the front upper strut bar will interfere with my cold air intake. I am a novice but want to improve my car's stiffness, and handling. I intend to add full coilovers and a zc upgrade, while replacing the wheel hubs and rear brakes to integra 90-93 discs. Thank you for your help.
first thing
what model/year is ur car
second do you have any kind of manual, Honda/Haynes/ect those will gie you a fairly good idea of where your looking. And yes you have to jack up the car., you'll also need to support the system as you swap pieces.
I have a pilot cold air intake and strut braces front and rear with no problem. I didn't go with the bottoms. But I did buy the rear strut brace first thinking it was for the front 'cause the web site I bought from didn't make it clear. But once I figured it out everything went smoothly and it makes a hellava diffenrence with dirving performance. Good luck.
