question about engine swap
Old Oct 9, 2002 | 05:19 PM
spanky's Avatar
spanky
I go duffy on dem bitches
Default question about engine swap
im considering buying a 4th gen sedan w/ a smoking motor. in order to place a 6th gen EX motor in it, i could change only the engine, right? of course i'd have to do some wiring adjustments, but other than wiring, what would need to be changed?
Old Oct 9, 2002 | 08:35 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: question about engine swap
if the 4th gen car is 89 or newer, then yes, you can use the existing transmission. The engien mounts should match right up to the newer sohc engine.
as far as wiring, you'll only need to change things if the car you're buying does NOT have multi-point fuel injection already. Otherwise, all you need is the VTEC wire and appropriate changes to make the VTEC work. You have a few different options for the VTEC.
Old Oct 10, 2002 | 05:02 AM
Shea-bird's Avatar
Shea-bird
yeah hopefully it has MPFI!!!!
Old Oct 10, 2002 | 01:25 PM
DAJDMJUNKY's Avatar
DAJDMJUNKY
chill factor performance
where do u get a cable to hydro conversion kit, i need one for my swap
Old Oct 10, 2002 | 02:46 PM
spanky's Avatar
spanky
www.hasport.com
