Engine swap
Old Apr 10, 2007 | 06:49 AM
aka-dk's Avatar
aka-dk
Caleb
Default Engine swap
Just wondering if i could swap my 1992 Integra b18a engine into a crx. If so, what year?
Old Apr 10, 2007 | 07:10 AM
jlicrx's Avatar
jlicrx
you could swap it into any 84-91 CRX but you would be better off sticking with the 88-91 models - the Si model would be the easiest to swap it into due to it already being wired for MPFI - the HF model is also MPFI and is a lot lighter than the Si, but you would need to swap out the front knuckles/hubs in order to use the Integra axles - the DX model would require doing the DPFI to MPFI wiring changes - it is also lighter than the Si model, but not as light as the HF - 88s are the lightest and 91s the heaviest
Old Apr 10, 2007 | 05:29 PM
daddiodanger's Avatar
daddiodanger
bad mo fo
it's a pretty standard swap. look around a bit and you will find all the info you need.
