what engine to go in to a 89 crx
Old Mar 17, 2007 | 08:03 PM
hockey25crx's Avatar
hockey25crx
Default what engine to go in to a 89 crx
i just bought an 1989 crx si it has a ton of mikles so i'm gona drive it till it dies. after that i want to make it my project car. i want to do an engine swap but don't know what to get i'm looking to spend abot 2000-2800 on the swap. i'm planing on then turbocharging it. i'm gona put a t4 or larger turbo in it so i need an engine that will handle that power at a higher psi. what should i get and what other things will i need except the ecu chip.
Old Mar 17, 2007 | 11:17 PM
gingas's Avatar
gingas
Most people that go for turbo usually go w/ a B18A & turbo. It's a lower compression motor than a Vtec. If you wasn't going turbo I'd recommend a B16A or B18C. Good luck
Old Mar 18, 2007 | 06:54 AM
Snoopy's Avatar
Snoopy
been there done that
you can get a full b18a/b swap for cheap. when fully built it doesnt really matter what engine you get.
Old Mar 19, 2007 | 10:00 AM
hockey25crx
how difficult would it be to puta 2nd gene engine with the hydrolic trans in?
Old Mar 20, 2007 | 12:32 PM
88crxTurbo's Avatar
88crxTurbo
Clean and Simple
Why do you want Hydraulic tranny??? its just more of a hassle. and if you do, depending on what engine you drop in they make the hydraulic to cable conversion im pretty sure. check out hasports site. I would deffidently go with a b18a and turbo it. I did the same swap in my 90 crx si, and its great. lots of torque. Drag turbo kits make a custom kit to fit the crx with the b18a swap check them out too. I am about to buy one they are around $3g's but should be well worth it. I will let you know
Old Mar 20, 2007 | 06:59 PM
hockey25crx
where can you find a b18a motor i can'tfind it online all i can fins are b18b, b18c, b16a.
Old Mar 23, 2007 | 07:07 AM
88crxTurbo's Avatar
88crxTurbo
Clean and Simple
Check out jspecauto.com they have some. if not them check out the favorite site of all honda owners...hmotorsonline.com. would call them and see if they can get you one, they might not have one on the page, but they might be able to get you one.
Old Mar 23, 2007 | 07:37 PM
iwant2race's Avatar
iwant2race
well i have a 89 hatchback and i want a hard hitting vtec and what engine should i get
Old Mar 25, 2007 | 09:49 AM
88crxTurbo's Avatar
88crxTurbo
Clean and Simple
well, a b16 sir is a good start, but if you have more deep pockets then go with a gsr motor or itr motor, b18c1, b18c5. all of those "scream like a first date" in the top rpm's.
Old Mar 25, 2007 | 10:22 AM
iwant2race's Avatar
iwant2race
so if i had a b16 in it and what should i do to the internals of the engine
and would i need anything done to the ecu
sorry for all the questions
i just want a fast hardd hitting vtec and a very clean ef thanks
