Fuel Pressure?
Old Nov 20, 2006 | 05:54 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Default Fuel Pressure?
What is the Stock fuel pressure suposed to be for a B16A?
I have intake and exhaust. What should mine be set at?
Old Nov 20, 2006 | 06:09 AM
jaje's Avatar
jaje
HC Racer H5
I don't recall a specific number but it normally is around 30-35psi for a fuel injected car.
Old Nov 20, 2006 | 11:38 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
30-35 at idle or WOT?
As is, it is set at 30 at idle, and goes to 40 at WOT.
Is that good for a stock B16 with exhaust and intake?
Old Nov 20, 2006 | 12:41 PM
jaje's Avatar
jaje
HC Racer H5
30-35 is at idle...40psi at WOT is fine for an n/a engine
if you have forced induction you want up to 60-70psi for WOT to prevent leaning out
Old Nov 21, 2006 | 11:46 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Ok, im good then.
Just wanted to make sure.
Thanks
Old Nov 23, 2006 | 02:57 PM
Kai's Avatar
Kai
Rotorphile.
Just looked up the spec for the B17A1- B16A is identical.
With the vacuum line removed from the regulator and plugged, a gauge between the fuel pump and regulator should read 48-56psi.
Spec for the B18A is 41-48psi. Odd that they are different.
Old Nov 28, 2006 | 04:17 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Ok cool, thanks.
