suspension?
Old Nov 28, 2006 | 08:27 PM
  #31
18crx's Avatar
18crx
stock booster
ok if u have been reading if u have 88 they wont fit unless u change ur lower control arms, if u have 89-91 they will fit. 88 is the only year they are diff, they go inside of the arm not over the arm. so if u get those off ebay and get some lcas off a 89 or 91 they will work un less they are for 88 spec..... nuff said. and coil overs will work without or with stock struts
Old Nov 28, 2006 | 08:28 PM
  #32
18crx's Avatar
18crx
stock booster
Originally Posted by 88'CRX
i would really like some coilovers though and i just wanna kno if those would be a good set
no
go for a few hund more and get a full body coilover
Old Nov 29, 2006 | 06:21 PM
  #33
88'CRX's Avatar
88'CRX
what else comes with full body coilovers????
Old Nov 29, 2006 | 08:44 PM
  #34
18crx's Avatar
18crx
stock booster
ok the higher end stuff which is a full coilover is...
adjustable ride height and preload on a strut that has the threads on the body of it that the spring perches go on up or down thats a full body coil over.
http://www.omnipowerusa.com/product.asp?P_ID=121
go here and check em out. then any other ?s get back
Old Nov 30, 2006 | 03:37 PM
  #35
88'CRX's Avatar
88'CRX
if only the 88 is different then why do they have a set for the 88-89 then another for the 90-91????
Old Nov 30, 2006 | 04:35 PM
  #36
18crx's Avatar
18crx
stock booster
trust me 88 is diff than all the rest if u dont belive me order some ofr 88-00 civic and find out.
Old Dec 1, 2006 | 09:05 AM
  #37
Tankard's Avatar
Tankard
I don't think anybody mentioned this. If your going to lower your car, the first thing you will need is a camber kit(at least on the front end), unless you want to buy new tires every 5k miles. When i bought my crx, it had lowering springs on it, without a camber kit. The front tires wore out on the inside edge in no time. I simply ordered some new stock springs, whick raised it back up and put the tires back at the correct camber, instead of getting a camber kit. I did'nt like the lowered back jarring ride. It did handle better, but i'm not into autocrossing or racing.
Old Dec 1, 2006 | 08:50 PM
  #38
racerdave's Avatar
racerdave
USAF C-17 Crewchief
The LCA's are different, I forgot, my bad.
All the cars I have had, I changed out the LCA to the box'd style.
Just go pull some off of a car at the junkyard, and box weld them, makes them stronger and not flex. Makes a HUGE difference. Tightens up the rear a lot.
You have gotten a ton of good advice on here, what have you decided?
Full coilovers, or sleeves, and struts?
