B16 Running strange?
well it also could be ur coolant temp sensor. if thats not reading right it will cause a miss or bog just of idle or when crusing cold or warm. the ecu uses coolant temp, tps, tdc, and map to inject proper fuel, when ones not working right it does random things, so check em all out sounds like a bunch of fun but process of elemination
Installed Injectors, fuel pressure gauge, and adjustable FPR, set at 30-40 PSI.
Didnt solve my missing, but wow, way more smooth...
Its nice..
So im still trying to figure it out..?
I have a Knock sensor code, plan on buying a new one soon.
Should I get that or the Coolant temp sensor first?
Its nice..
