Old 87 Si- Idle issues?
Old Sep 29, 2002 | 04:56 PM
Kai's Avatar
Kai
Rotorphile.
Default Old 87 Si- Idle issues?
I figured maybe you guys could help me out before I limp (figurativey, it still drives fine) my 87 Civic Si to the dealer for a tech inspection. The problem is, when it is about halfway through warming up the idle will bounce between the 1500 cold idle and the standard 750 idle, and it will do this for a few minutes until it warms up and catches itself. From there, it idles as normal. I have already replaced the cap and rotor, plugs, and wires to no avail. Also, when I am driving and rev over 3.5k the tach jumps all around, till about 1000 from redline- then it goes up smooth. I know the clutch is getting weak, but that tach problem might help explain what is going on with my idle. TIA!
Old Sep 30, 2002 | 04:55 PM
Kai's Avatar
Kai
Rotorphile.
Anyone? I also replaced the PCV valve and fuel filter, I forgot to mention that. I'd rather not pay the $ for a diagnostic test!
Old Oct 1, 2002 | 07:35 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Sounds like a leak in the throttle body gaskets to me. If not that, start checking for some vacuum leaks. Our cars are pretty old, the rubber stuff is aged.
-Harry
AIM: NDcissive
Old Oct 1, 2002 | 10:03 AM
jaje's Avatar
jaje
HC Racer H5
where are you at?...maybe you can stop by my place and we both can figure out what's wrong...i'm in herndon, va
email me: jjkarns@yahoo.com
