B16 axle and clutch cable problems
Old May 30, 2006 | 09:02 AM
nexgen91's Avatar
nexgen91
Gearhead
Default B16 axle and clutch cable problems
i have put a b16 in my 91 civic, now when I ordered axles I ordered 91 integra ones, but they will not fit (well one will but the one on the intermidiate shaft side will not). maybe I have the wrong axles? i dont know. im using the integra intermidiate shaft also I need to know how to mod my stock clutch cable to hook up to the b16? any help would be great. thanks
Old May 30, 2006 | 10:05 AM
teg92's Avatar
teg92
WHAT OK YEAH!
if your using and integra intermediate shaft the axle should work. Are you using a manual or automatic intermediate shaft?
Old May 30, 2006 | 06:35 PM
91civicb16a's Avatar
91civicb16a
when i put the first b16a into my 91 hatch i had a problem like yours 91integra on the passenger side but the 91 integra wouldnt fit on drivers side with the intermediate shaft. I used a drivers side axle from a 89 integra and it worked perfectly. I think i used the 89 integra intermediate shaft also, but im not sure.
Old Jun 1, 2006 | 10:02 PM
madman4you's Avatar
madman4you
get a clutch cable from a 90-93 integra aswell
Old Jun 3, 2006 | 06:12 PM
nexgen91's Avatar
nexgen91
Gearhead
i got a 90 teg manual int shaft and axle, im going to try to put the inner joint off a jdm axle (one came with my engine) on there and use the jdm int shaft with it. wish me luck. thanks
