So i decided on a basic ZC swap.
Old May 27, 2006 | 06:24 PM
Haste The Day's Avatar
Haste The Day
Default So i decided on a basic ZC swap.
Im gonna order a ZC and use my Si tranny, and axles. I'm getting the
Motor, Intake Manifold, Exhaust Manifold, Injectors, Fuel Rail, Throttle body, Alternator, Distributor and the PM7 ECU. I know it basically bolts right in but just curious if there is any wiring i need to do with the setup im gonna use. Thanks in advance.
Old May 28, 2006 | 03:12 AM
Kai's Avatar
Kai
Rotorphile.
Since it sounds like you already have an Si, there isn't much to worry about. Base and DX/LX guys have to convert to MPFI, but the Si chassis comes wired as such stock.
Old May 28, 2006 | 03:42 PM
Haste The Day
Awesome..Yah i have an Si, so its pretty much bolt it in connect all hoses and do all the normal sstuff?
Old May 28, 2006 | 05:42 PM
91civicse's Avatar
91civicse
this little web site gives you a nice walkthrough, not the best but might help you out a bit..
http://www.phatwhippincrx.20m.com/photo6.html
Old May 29, 2006 | 06:19 AM
91civicb16a's Avatar
91civicb16a
u have to run two wires to the ecu for the cam angle sensor.
Old May 29, 2006 | 10:15 AM
Haste The Day
I have to run wires even though its the ZC ecu?
Old May 29, 2006 | 11:40 AM
Exempt's Avatar
Exempt
2 tone Rex
Yes, but I think your wiring harness has the wires already, they are just in a different location... So you just have to trace them down and then wire them to the cam angle sensor (on the end of the exhaust cam I believe)... May just be easier to go straight to the ECU tho... I dont remember off hand where these wires are on the A6 harness... I think they may be in the disributor wiring...
Old May 29, 2006 | 06:28 PM
gutterslide's Avatar
gutterslide
http://fourthgenhatch.net/zc.html
