spare tire question
Old May 20, 2006 | 09:59 PM
crxmex's Avatar
crxmex
Default spare tire question
what is the spare tire psi supposed to be at on a 105/80/13:bandito:
Old May 21, 2006 | 12:25 AM
Kai's Avatar
Kai
Rotorphile.
It is printed right on the sidewall, 60psi.
Old May 21, 2006 | 07:50 AM
crxmex's Avatar
crxmex
very true sir. it does say max weight xxx at 60psi. but it's super super super hard at just 25 psi. afraid for it to blow.
Old May 21, 2006 | 09:45 AM
Exempt's Avatar
Exempt
2 tone Rex
Depends on different things like weather, alignment, road conditions, ect... When I went to get mine aligned, the guy told me to keep the fronts at 50 PSI because I have a slight negative camber issue in the front... My tires are rated at 55 max PSI...
Heres a page which tells you a little bit about proper tire pressure...
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
Old May 21, 2006 | 07:54 PM
crxmex's Avatar
crxmex
talkin bout the spare tire "in the trunk, used for flats and such." thanks for the input though
Old May 22, 2006 | 08:02 PM
Kai's Avatar
Kai
Rotorphile.
Spare tire. Honda compact spare tires should be inflated to 60 PSI, no more, no less.
Normal tires should be inflated as per the manufacturer's sticker in the driver's door jamb. 32psi for most Honda vehicles. Too much more then that and you will increase the wear to the inside of the tread.
Old May 23, 2006 | 08:09 PM
Exempt's Avatar
Exempt
2 tone Rex
Yea, I didnt see spare tire... h:
Old May 24, 2006 | 09:28 PM
waaBAAH's Avatar
waaBAAH
not true. to much psi over manufaqctur rating will increase tread wear in the middle. to less and you increase wear on the outsides of the tire. both inside and outside.
even with camber issues you still create tire wear anyway you look at it. it is kind of like saying.....make the car toed in ( / \ ) to even the wear for your negative camber. sure...in theory your tires would wear evenly but why sacrifice handling for even wear? cant have best of both worlds....either handling...or tire wear...pick one
Old May 25, 2006 | 07:22 PM
crxmex's Avatar
crxmex
Default not to be a "dick" but the question was for the spare.
i wanted to know the proper psi for the spare tire in the trunk nothing more or less thanks for the repsonses so far but it was dedicated to the spare.....for the "just in case i get a flat" situation
Old May 25, 2006 | 07:40 PM
waaBAAH's Avatar
waaBAAH
already stated.....60 psi and i am sure you know this by now
