Optima Battery?
Old Apr 28, 2006 | 03:27 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Default Optima Battery?
I bought a Optima battery so I can move the battery into the rear.
I wanted to know if I should I run them on the outside or inside of the car?
Dont worry im not going to run them anywhere near any other lines or exhaust... I have insulated holders and everything is ready to go in, I just need to know where to run the positive and negative leads? Outside or inside?
Old Apr 28, 2006 | 04:34 PM
josejtorres's Avatar
josejtorres
i did it on the inside. in case shi# happens
Old Apr 28, 2006 | 08:57 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
hmm, I was worried about doing it on the inside cuz I have heard stories of cars burning to the ground like that..
Anyone else think it is safe?
Old Apr 30, 2006 | 02:23 PM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
When I bought my rex, the battery was already relocated to the back. The wire are run on the inside of the car. I was worried about it cuz the wires get a bit warm, but it should be fine if you're running a heavy gauge wire.
Old Apr 30, 2006 | 06:21 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Mine was relocated too, just run a 4 gauge wire and u will be fine. That optima is kinda heavy tho.
Old May 1, 2006 | 01:43 AM
Kai's Avatar
Kai
Rotorphile.
Wires are run inside the car, fuel and nitrous should be run outside.
Old May 3, 2006 | 05:10 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Heavy? well.. I figured it would be the best battery I can get to put inside without a vented battery box, it says it is fume/leak free... I was planning on mounting it in the very back passenger side corner, or should I do it right where the spare tire was?
As far as weight distribution, what should I do? I currently have a B16 in the front, took out the spare tire, and lower interior from the hatch back.
Plans are Koni adjustables w/coilovers, and a rear stut/sway bar.
I dont like the battery in the engine bay, it just does not seem right...
Ideas?
Old May 20, 2006 | 09:03 PM
juiceweazel's Avatar
juiceweazel
Mobfather of all
NEVER run power cables on the outside of the car! Way too much shit can happen. I had double 2 guage in my teggy for the stereo, never had a problem.
