what is my wheel offset/bolt pattern?
Old Apr 23, 2006 | 02:19 PM
nexgen91's Avatar
nexgen91
Gearhead
Default what is my wheel offset/bolt pattern?
i have a 91 civic hatchback, can anyone tell me what my wheel offset and bolt pattern is? thanks
Old Apr 23, 2006 | 03:53 PM
Exempt's Avatar
Exempt
2 tone Rex
4x100 lug pattern... Which offset you need to buy depends on the rim, tire, springs (how low u are dropped if at all), ect... Stock I believe they have a +38mm offset... Could be wrong tho...
Old Apr 24, 2006 | 03:47 AM
nexgen91's Avatar
nexgen91
Gearhead
does it matter what offset I use? thanks
Old Apr 24, 2006 | 07:52 AM
randomtask77's Avatar
randomtask77
Wanderer
Offset should be between +40mm to +45mm.
But like exempt said, you gotta take into consideration your tire width and your drop as your offset will determine how much your wheels are going to stick out (or in) your fender.
Old Apr 24, 2006 | 06:55 PM
Kai's Avatar
Kai
Rotorphile.
To far to the negative and it will hit the brakes and suspension. Too far positive and it will stick out of the wheel well.
