temp problem
Old Apr 21, 2006 | 01:20 PM
loweredcustoms's Avatar
loweredcustoms
Jason
Default temp problem
ok i bought a 89 civic about 7 months ago and in the beginning the thermostat guage only read 1/4 of the way up and at the end of winter the warmer it got out the gauge will go up about 3/4 of the way up about 2 months ago the head gasket blew and i redid the headgasket and it was still running hot so i re wired the fan and put it on a switch so i can control it i replaced all hoses and the thermostat and it was still getting hot so then i flushed the radiator system and its still hot can someone help me im lost and dont know what to do?
Old Apr 21, 2006 | 01:29 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
You didnt replace the thermostat yet
Old Apr 21, 2006 | 03:51 PM
xpman's Avatar
xpman
Please don't think I'm trying to insult you but did you bleed any air out of the cooling system after filling it back up? There's a little bleeder fitting but I can't remember exactly where. I know it's somewhere on the top that's easy to get to.
Old Apr 21, 2006 | 03:53 PM
crzy000's Avatar
crzy000
if you had a head blown gasket, did you have the head re -shave? most of the time when you get a blown headgasket the head will warp. also check your water pump if it's doing his job.
Old Apr 22, 2006 | 12:21 AM
Kai's Avatar
Kai
Rotorphile.
Don't do that. I have seen a few engines blow because the owner wired in a fan switch and forgot to turn it on, as well as a few dead batteries from owners forgetting to turn the fan off.
Old Apr 22, 2006 | 11:11 AM
loweredcustoms
Jason
yes i have changed the thermostat
Old Apr 22, 2006 | 11:17 AM
loweredcustoms
Jason
no i didnt bleed anything i just let the car warm up with the radiator cap off and when it was warm put the cap back on
