speedometer problem
Old Mar 23, 2006 | 09:35 AM
crzy000's Avatar
crzy000
Default speedometer problem
I did a mini swap on my 89 crx. new piston,ported head, new valve and etc. took it down for a good run down. Car pull very on all gear from 1-5. but my question is the speedometer only goes up to 80. But I still can feel the car pull when I floor it down. Is there a limited speed on the 89 crx speedometer?
Old Mar 23, 2006 | 09:43 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
It may only go up to 80 it depends on far the ECU will let you go.
Old Mar 23, 2006 | 09:52 AM
crzy000's Avatar
crzy000
I'm using a p28 ecu that have been chip. is there anything I can do to fix the problem?
Old Mar 23, 2006 | 10:13 AM
F22B Prelude
Rachel Bilson
If your car keeps going then it keeps going...the limiter is in the ECU not the speedometer...you might be able to find an after market speedometer youll have to look though.
Old Mar 23, 2006 | 10:24 AM
crzy000's Avatar
crzy000
thank's alot F22b Prelude. I thought I could get away with the ecu being fix.
Old Mar 23, 2006 | 10:32 AM
F22B Prelude
Rachel Bilson
I would still keep my eyes on the REV meter...just cause your engine can keep going doesnt mean you should.
