Port and Polish???
Old Sep 14, 2002 | 04:35 AM
SlowCivicHmm's Avatar
SlowCivicHmm
Default Port and Polish???
What benefits will I see if I port and polish my ZC motor??? I have I/H/E and FPR........that's it.....I cant get a full port and polish and 3 angle valve job for like 200 bucks.....that sounds like a good deal from what I have heard....but I never really did research on this type of stuff....
WHat does a port and polish do?? 3 ro 5 angle valve cut????
ANy in put would be great....thanks
Old Sep 14, 2002 | 06:19 AM
qtiger's Avatar
qtiger
A port and polish is only as good as the person doing it. Don't trust a domestic P&P shop to know what they are doing with an import motor.
Simply put, all a P&P does is allow your engine to flow more air by removing all the rough surfaces, casting imperfections, etc, (polishing) and widening out/port matching your ports. On Honda engines there is very little enlarging of the ports.
Old Sep 14, 2002 | 06:54 AM
crxrocks's Avatar
crxrocks
Do not polish the intake manifold or the intake ports on the head. The rough material should be there to help mix the air/fuel. You can remove casting marks, etc, but don't polish it out.
Chris
Old Sep 14, 2002 | 09:40 AM
SlowCivicHmm
hmmm......so the exhaust ports and mani get ported or enlarged right???? same with the intake mani and the TB right...tb gets bored no ported............so I can port everything but don't polish the intake parts??? that correct.....more info.......
ttt
Old Sep 14, 2002 | 10:21 AM
jaje's Avatar
jaje
HC Racer H5
if you port & polish i'd only do the exhaust ports...b/c the intake is designed to create a swirl to efficiently mix the gas/air to get a more powerful explosion...a professional shop would be able to keep the proper swirl effect along with increasing airflow when by hand by an amateur will not know what to do (i don't)
Old Sep 14, 2002 | 10:48 AM
SlowCivicHmm
does anything in the head get ported?? or polished?? Im extremely new to internal work...Im a bolt on type of guy....haha.......I'm just learning on internals...
Old Sep 14, 2002 | 11:31 AM
jaje's Avatar
jaje
HC Racer H5
a professional job will including the port & polish of the intake and exhaust ports as well as polishing the cylinder head part of the combustion area...i've never had a chance to see what is actually done but this is what i'm sure of that happens...some other shops may do many other things
Old Sep 16, 2002 | 03:28 AM
SlowCivicHmm
TTT....any info on the valve job?? 3 angle or 5 and what excatly does it do....
Old Sep 16, 2002 | 04:17 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
You only need a 3 angle job on a street engine, the purpose is to make the valve more aerodynamic, but a 5 angle job can make the valve head more prone to damage/cracking.
-Harry
AIM: NDcissive
Old Sep 16, 2002 | 09:28 PM
SlowCivicHmm
thanks...
aznboi64
Mar 8, 2004 07:43 AM
aznboi64
Mar 2, 2004 10:41 AM
The Bum
Engine Swaps, Tech & Tuning
9
Oct 31, 2002 05:08 PM
Chrgsr96
9
Oct 12, 2002 01:54 PM
