Brain fart on compression test:
Old Nov 22, 2005 | 05:26 AM
m735is's Avatar
m735is
Default Brain fart on compression test:
88 Civic 1.5 hatch:
How do I disable the fuel or ignition or both and still be able to crank the engine with the key?
Thanks.
Old Nov 22, 2005 | 06:18 AM
mr.crx's Avatar
mr.crx
Well if you are trying to do a compression test as i assume that you are, all you have to do is take out your spark plugs. Unplug one of the distributor connections and the car will turn over but not start because its getting no spark so you can check the compression. then once you get your answer put it all back together and go driving!
Old Nov 22, 2005 | 08:51 AM
jaje's Avatar
jaje
HC Racer H5
i can't remember but all you need to do is just pull a fuse for the PGM-FI and just turn over the engine...i'm thinking its the #37 fuse but its been a long time since i've done that on a crx
Old Nov 22, 2005 | 09:22 AM
m735is's Avatar
m735is
Nice, thanks.
Yes I'm doing a comp test, just curious before I take the head off (even though it won't tell me if the head is cracked).
