Is a Aftermaarket Crank Pulley Better?
Old Nov 22, 2005 | 04:28 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default Is a Aftermaarket Crank Pulley Better?
Well, the only belt I have on my car is the alternator belt. If I get an aftermarket crank pulley, will that be better?
Old Nov 22, 2005 | 08:24 AM
Tankard's Avatar
Tankard
I searched for lightened crank pulley and read some advantages and disadvantages. From what i read, i'd say stick with the stock one. For example, i read the stock one has a rubber ring in it, which helps reduce engine vibration.
Old Nov 22, 2005 | 08:30 AM
teg92's Avatar
teg92
WHAT OK YEAH!
CTR pully is nice, and its Genuine Honda part
Old Nov 24, 2005 | 09:23 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I have heard horror stories from the CTR N1 pulley as well. I would just stick with stock even though you only have 1 out of 3 belts on it.
Old Nov 28, 2005 | 09:15 AM
daddiodanger's Avatar
daddiodanger
bad mo fo
the stock one also has timing lines on it.
Old Nov 28, 2005 | 03:42 PM
EQMD EF8's Avatar
EQMD EF8
CTR N1 also has timing marks. So does my UR pulley. Most REAL aftermarket pulley's have timing marks. Ebay pulleys don't, but you can put your own on them. Underdrive pulley's have been around for about as long as street racing has. Old american cars have used them for years and never had a problem. And they are actually replacing their harmonic dampers with steel underdrive pulleys. It's a garenteed way to increase wheel hp.
Old Nov 29, 2005 | 08:58 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
well, i'd trust the CTR N1 pulley. its made by honda to be a STOCK pulley on a Civic that didnt come with power steering or A/C. if u dont have either, i dont see a problem with it. i have that crank pulley on my LS.
Old Nov 29, 2005 | 09:29 PM
RedlineBoyzCRX
EG6
How much does that CTR N1 Pulley cost?
Old Nov 29, 2005 | 09:55 PM
Provocateur
On permanent hiatus
http://www.inlinefour.com/ctrn1cranpul.html
