What is Code 6?
Old Nov 20, 2005 | 03:38 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default What is Code 6?
Well, I got a code 6 on my car and I don't know what it is. What is it?
Old Nov 20, 2005 | 11:16 PM
Kai's Avatar
Kai
Rotorphile.
Google Dot Com.
Code 6 : Engine Coolant Temperature sensor.
Check the wiring to the sensor, then check the sensor resistance by temperature.
Old Nov 20, 2005 | 11:40 PM
mula's Avatar
mula
does the vtech kick ? if so just reset the ECU by pulling the fuse under the shock tower.. pull it out and wait for 30 seconds.. that should take care of it.. good luck
Old Nov 21, 2005 | 04:02 AM
RedlineBoyzCRX
EG6
What do you mean VTEC kick?
Old Nov 21, 2005 | 04:19 AM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
Vtec will not engage if your ecu is flashing a code or CEL is on, even if you've fixed the problem. You have to reset the ecu, then see if everything is okay.
BTW, here is a link to an ecu code list with most codes listed. http://www.integra.orcon.net.nz/ecucodes
