b20/vtec
Old Nov 17, 2005 | 05:45 PM
dapump2003's Avatar
dapump2003
Default b20/vtec
i own a 88 crx hf swap b20/vtec.. i did a b17 tranny swap on it recently and now i am having issue with the motor.. previsouly i had a b18 LS tranny.. i took off the LS tranny and threw a lighten flywheel for a b17 and threw the B17 GSr tranny on it.. the problem is that,
1. i have no pressure on the clutch
2. the car won't go in gear
3. everytime i gas the car and let it go, the car dies
does anyone might have any suggestion what could be the problem.. i ground all my wires, i torque everything to spec.. now i am lost on why is it doing this..
thanks
Charlie
Old Nov 17, 2005 | 10:44 PM
PacificDude's Avatar
PacificDude
Sharkbait OOHAHA!
My guess is you need the right flywheel/clutch for your transmission application. IDK if those parts are interchangable, even if they are b-series motors. Do a search on a B20 v-tech swap and see what they did to make it work. You may find some other valuable info that you didn't know you needed
