Code 8
Old Nov 11, 2005 | 02:37 PM
efhatch's Avatar
efhatch
Default Code 8
Okay here's the problem I'm having. I just finished doing a b16 swap into my dx and after we got everything all wired up and stuff and tried starting it the ecu is throwing a code 8 which is TDC sensor, so we swapped out the distributor and it still wont start, it cranks but it will not turn over any ideas?
Old Nov 12, 2005 | 10:24 AM
efhatch's Avatar
efhatch
Okay got the code 8 gone and the car starts now, but it's throwing codes 7 and 14 nowand those are tps and iac....... just trying to chase those down and I should be good to go
Old Nov 12, 2005 | 03:17 PM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Does it Spark?
Old Nov 12, 2005 | 10:37 PM
Magic Carpet's Avatar
Magic Carpet
If you got em, burn em!
i had a code 7 and 16 on my car but it was the fuel injector messing up. it has happened twice now and i dont know why those two codes come when the injector messes up. problems are solved now.
