need electrical help for 88 crx si
when you start does the main fuse relay click or does it mean its bad ? i got a code 20 wich means a ground error the car wont start at all any sugg ?thanks don
are main relay replacements commom problem on crx ?
does any one know if this is a common issue ?i am a new to hondas i am a ford (mazda)and bmw guy . i bought this car for future auto x and to drive to save on gas
89 CRX si, now with b16!
Code 20 is eletrical load, but maybe that means bad ground too? Anyway, yes..the main relay is supposed to click once when u turn the key to start, and again when the CEL turns off, then again I believe while your starting the car.
Also, yes.. the main relay going out is a common problem on early hondas. It shouldn't be an issue now though, since it typically happens when the ambient temperature is hot, like summer. So I don't believe your relay is the culprit. Have u checked plugs, wires, cap, rotor, and fuel pump? If it is your relay though, it costs about $70 at most dealerships, but the new relay is supposed to be alot better.
thanks i bought a new relay on ebay but not problem
i have to change the disty i did all new plugs and wires except cap . car has been sitting before buying but disty looked new
