Does the front ground wire on the car matter?
Old Oct 31, 2005 | 04:16 AM
RedlineBoyzCRX's Avatar
RedlineBoyzCRX
EG6
Default Does the front ground wire on the car matter?
I took the Front ground wire off of my car, does it matter all that much?
Old Oct 31, 2005 | 05:27 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
i don't know if it will matter a whole lot, but it probably helped a little bit.
why would you take it off? weight reduction? :lmao:
Old Oct 31, 2005 | 08:53 AM
mullinator's Avatar
mullinator
I would never remove the ground on a fuel injected car. Too much engine management relies on reliable voltage potentials. W/o a front ground, your throttle position sensor is talking through your hatch somewhere. I've tracked all sorts of gremlins down to proper power and ground. -scott
Old Oct 31, 2005 | 09:16 AM
RedlineBoyzCRX
EG6
Alright, I guess I will put it back.
Old Oct 31, 2005 | 01:01 PM
Tankard's Avatar
Tankard
I just by passed my fuel filter to see if i can get better fuel flow. Does it matter? Just messing with you man. Was your intention really for weight ruduction? h:
Old Nov 2, 2005 | 04:04 AM
RedlineBoyzCRX
EG6
NO it wasn't weight reduction. Ijsut took it off, because I was too lazy to put it backon. That's why i asked if it mattered that much.
Old Nov 2, 2005 | 05:35 PM
tempuus's Avatar
tempuus
u charging system will go to shit my battery went dead 4 times in one week and honda told me it was that wire so i used some 8 guage i had layin around now all my electrical problems have seased
Old Nov 3, 2005 | 04:46 AM
Hondaisok's Avatar
Hondaisok
I had a problem after changing my engine where that wire would heat up and melt on me when I was trying to start the car (the car started hard also). I replaced the wire and ran another wire from my negative battery cable to my engine block, by the distributor. I also ran another wire from my body in front to the engine block in back. Haven't had a problem since.
Old Nov 4, 2005 | 03:57 AM
RedlineBoyzCRX
EG6
If I put the front ground wire back on, and then I run another Cable from the negative battery terminal to the engine block, do you think my car will start easier and run better?
Old Nov 4, 2005 | 07:27 AM
Hondaisok's Avatar
Hondaisok
The way I look at it is, it can't hurt to have an extra ground connection.
