V-tec not turning on??
On permanent hiatus
Originally Posted by crzy000
okay guys got the primary 02 sensor done. where do I start with the ignition?
On permanent hiatus
thank's Schmoo, I think I will have to get that helms manual. At the mean time where do you think I should start with the ignition problem?
If you could pinpoint what area of the ignition system it says is faulty, it would be easier to determine where to start.
So in essence, what is the description of the code?
okay guys I finally got the cell code out. But I'm still having problem with the v-tec not turning on. Instead I'm having white smoke now when I pound my car. Man the car is just giving me problem one after another. I think I should just remove the e-management. Anyone have any picture on how to hook up the v-tec switch and solenoid on a obd0 wiring harness.This way I can remove the boomslang conversion wiring harness.
